compatible Guage cluster?
I have a 92 sc 1.9, 5spd. The Odometer does not work. I found a guage cluster in a salvage yard the car was marked a 1992. There is a differance in them, the oil pressure guage, mine has one the other dosn't. It has a light instead. Will it still work in my car?
No. You need a 1991 or 1992 DOHC gauge cluster. Or you can pick up a 1991-1994 SOHC or DOHC cluster and swap over just the odometers. Or you can buy the little gear that causes this problem and swap at out as well.
OK, Thank You, I will swap out the Odometer. If the fuel gauge shows erratic movement(like when turning it will move about a half a tank both ways) until the fuel settles down then flutters while driving. At stop it will slow to a steady normal state. Is this the fuel pump sending unit?
