Cranks, but no start
Old 12-19-2022, 01:56 PM
Hupp36's Avatar
Update, removed starter, bench tested, its dead, ordered a new starter, ask me if i am a happy camper, YES
  #42
Old 12-23-2022, 07:54 AM
Hupp36's Avatar
Installed new starter, engine runs spraying gas in the intake. No power in the trunk going to the fuel pump. Will go back over the notes to see how to fix that problem. I feel that I am almost there, just need 1 more thing Fuel to the engine.
  #43
Old 12-23-2022, 08:05 AM
Dude's Avatar
Mornon Hupp, Check yer fuse under the hood, if good maybe try hitting bottom of fuel tank w/hammer,
If pumps faulty often bumping it will start it due to worn brushes............Merry Pre-Christmas!
  #44
Old 12-23-2022, 12:57 PM
Hupp36's Avatar
Thank you for the Merry Christmas and a Merry Christmas to you and your family. The fuse's are good. I put a new fuel pump in the tank before all the other problems started to come up. I have with a lot of help off this forum, solved all the problems but no power to the fuel pump. I am sure that before I turn 83 years old next month, with help, we will solve this problem and my little jewel will be running again.
  #45
Old 12-23-2022, 02:14 PM
Dude's Avatar
For sure. Merry Christmas to you and yours.
  #46
Old 12-23-2022, 06:38 PM
Does the door chime work when the keys are left in the ignition and you open the driver's door?
  #47
Old 12-23-2022, 08:18 PM
Hupp36's Avatar
? I will check in the morning as i do not know . Thank you.
  #48
Old 12-24-2022, 03:05 AM
Also check the dome light. Comes on when you pull the switch all the way forwards.
And the charging port on the dash where you plug in your phone to charge. Does it get a lot of use?
No, I am not messing with you one bit. I would not do that. Sir. There is a method to my madness
Dude, If you know what I'm checking for,
  #49
Old 12-24-2022, 03:54 AM
Dude's Avatar
Hupp/derf I'm guessing BCM? This concerns me......."I put a new fuel pump in the tank before all the other problems started to come up" Did something go amiss w/new pump or connections? If relay clicks why isn't
pump running?
Standing by.........
  #50
Old 12-24-2022, 11:16 AM
Hupp36's Avatar
First answer, when I open the drivers door with the key in the ignition no door alarm. Dome light comes with the dome light switch. With the key in the run position, all the dash lights come on with the alarm. After a few seconds, all the other lights go out except the oil, fuel, service engine soon, picture of a fuel pump and a pic of set belt. I felt the fuel pump relay and it clicks, the car sitting for a year, I think I will put some gas in it.
Quick Reply: Cranks, but no start
