Filling the transmission
Okay, this was strange, but I don't know if it's common or not. After I drained the transmission fluid and changed the filter this morning, as I was refilling the transmission, it burped on me an puked quite a bit of fluid out of my funnel. I've never had this happen on any Mopar I ever owned (50 plus). Is this just a quirk of the Saturn transmission? I spent a good twenty minutes cleaning it all up. I didn't want it getting hot and stinking up the car. I drained a gallon out. Does this sound normal? I put a gallon back in and the level looks good. I had to add it very slowly as it wanted to burp on me a couple of more times. Has this ever happened to any of you?
I went back to my parts yard last night to check out some Saturn automatics and as far as I can tell, the fill tube/dipstick assy. is the only vent. When the dipstick is seated it still breathes through the very center and under the handle. I knew it had to have a vent on it somewhere. The manual transmission vent is a little more obvious.
Bobbed06
10-31-2012 10:09 AM
