Fog Light Change
Old 11-07-2008 | 12:48 PM
rafolas's Avatar
How do i change the fog light on a sc2 1997?
Old 11-07-2008 | 06:21 PM
Get under the car, reach up, turn the socket, disconnet bulb from pigtail.
Old 11-08-2008 | 04:32 AM
rafolas's Avatar
So, i tried that before i post here
i can disconnect the cables but i cant get the bulb off, and i need to open the foggy light somehow because the bulb inside is broken
Old 11-08-2008 | 09:11 AM
The foglamp is a sealed unit. The socket that has the wires on it that the bulb is plugged into comes out with a half turn.
Bloomington?Edited by: sw2cam
Old 11-08-2008 | 10:35 AM
Low Saturn's Avatar
If the blub glass broke inside the housing, then you''ll need to remove the housing to shake out the glass. That is done by removing the front fascia.
02saturn85051
06-12-2013 08:59 PM
sc2fan24
03-28-2010 02:36 PM
paulsl2
08-02-2009 08:30 AM
paulsl2
06-08-2009 02:36 PM
a-NiC
04-06-2009 05:29 PM
