Ignition Cylinder Lock??
Old 01-13-2009 | 11:14 AM
richie6's Avatar
Has anyone ever replaced their ignition? Key is stuck and can''t remove it....
Old 01-13-2009 | 03:04 PM
Low Saturn's Avatar
Yes I have. Usually theres difficulty with the ignition cylinder before the key actually gets stuck. You''ll have to remove the shroud and if you''re luck, when you press the little button to remove the cylinder, it''ll slide out. If not break out the drill/grinder and have at it.
Old 01-13-2009 | 03:15 PM
richie6's Avatar
What type of button do you hit...
SC2
08-04-2022 08:30 AM
wyndance
11-07-2012 10:37 AM
mpace001
10-24-2012 10:57 AM
jess
08-04-2007 10:53 AM
Saturnman
06-18-2006 12:16 PM
