Power windows
I have a 2001 sc2 . My problem started a couple months ago, the drivers side window would go down but not go back up. Eventually it would go up. But this last time it just stayed down. When I push the switch I could here the window motor click quietly. I have cleaned the switch but that didn't help. I have had the front and back door panels off on one inside there's metal blocking the motor and on the other the window is blocking it. Am I missing something or is there a way to get the window up manually? I would like to try to fix this myself but I'm out of ideas.Edited by: sw2cam
Remove the outter panel and replace the regulator. Instructions are in the tech section on my website.
Different Racing
While someone is pushing the up button, use the palms of your hands and push up the glass.Edited by: Low Saturn
Different Racing
