Sputtering around 4000 RPM
Old 11-19-2008 | 12:31 PM
jimmyslide's Avatar
Now that I have fixed the Alt. I notice another problem with the G/F''s car.
It seems as if the rev limiter is kicking in just shy of 4000 RPM''s. Red line is much higher, so I find it wierd for this to be happening. It runs perfect up until that RPM, then it just has no more and just sputters. I will do some testing and replace a few pieces, just wanted some quick opinions and other views.
Thanks
Old 11-19-2008 | 04:05 PM
Low Saturn's Avatar
Does it do that in neutral or in gear?
Old 11-19-2008 | 08:15 PM
jimmyslide's Avatar
In neutral...not sure about in gear. It''s the g/f''s car and I rarely drive it.
I don''t know frickin'' saturns! GRRR
Old 11-19-2008 | 08:20 PM
Low Saturn's Avatar
Then its normal. The neutral rev limiter is around 4000. The in gear rev limiter is around 6500 for a DOHC.
Old 11-19-2008 | 11:48 PM
jimmyslide's Avatar
Awesome. Thanks a lot Mike. Greatly appreciated. I was thinking it was normal as nothing was registering wrong and nothing was affected. I did some voltage testing and everything appeared to work properly.
Old 11-20-2008 | 10:10 AM
Low Saturn's Avatar
Voltage is important, but amperage is just as important. You could have the correct amount of volts, but low amperage.
drakedad3
03-04-2019 10:37 PM
uncljohn
12-06-2010 02:42 AM
AZJoeD
06-03-2008 08:17 PM
Itsnotme1988
04-25-2008 08:23 AM
sborn9
05-01-2007 08:32 PM
