water in my trunk
Check to make sure the weatherstripping around the lip of the trunk area is pushed on all the way, and also check to make sure it's not damaged (rips, dry-rotted, deformed, etc)
-S-Turn-Edited by: GarrenNatas
hey man if you have anything in your trunk that could be stopping your truck from cosing all the way or if you have befor but slamed it shut and bent something that will deffinitly leave a opening for water i had the same thing happen i came home to about 6 inches of water sitting with my spare tire i had to drill a bunch of holes to help pump it out so let me know if that helps you
jon
jon
on my 99 sc1, the backup lights don't work because they were full of water. that is where the leak is probably coming from. the lights are mounted in the trunk lid and if the seal is worn it will leak into the trunk.
