Down on power.
Old 09-29-2012 | 04:41 PM
08astraxr's Avatar
Default Down on power.
Hey guys I have a question. With in the last few days I've been having really sluggish acceleration. If I give it 100% throttle it just falls in its face and goes no where really. It will also start flashing the check engine light at me. The light then goes off when I let off the gas. It seems the more load that is on the car ( like giving full throttle in a high gear at low speeds) the worse the sputtering is. The car is a 5 speed 2008 saturn astra with 29000 miles. Everything is stock. It has not had a "tune up" either. Ive read about a sensor that seems to go out on this car a lot. anyway,, If you need more info please let me know. Thanks ahead of time!
Old 09-29-2012 | 05:48 PM
By any chance, is your car equipped with traction control ??
Old 09-29-2012 | 06:47 PM
I was going to suggest a clogged cat con, but with that little amount of miles on it, I don't think that's it.
Old 09-30-2012 | 12:42 PM
08astraxr's Avatar
Yes the car has traction control. I've turned it off and the car acts the same way. also when the traction control is on and is activated I have a light on the dash that comes on. I was actually testing the traction control last night ( in the rain of course) lol but it seems to be working right.
Old 09-30-2012 | 12:46 PM
08astraxr's Avatar
That crossed my mind as well. But I think it's a little early to have a clogged cat. I'm hoping its just bad gas or something simple.
Old 09-30-2012 | 09:28 PM
Could very well be a bad sensor.............check for codes brother.
Old 09-30-2012 | 09:49 PM
08astraxr's Avatar
Will it still store a code if the check engine light is not staying on?
Old 09-30-2012 | 10:19 PM
Late model cars will store historical codes but i don't know that the average scanner can access them. If you get the codes read somewhere specifically ask them to read historical codes too
Old 10-01-2012 | 07:53 PM
08astraxr's Avatar
I'm thinking the whole problem might have been some bad gas. I got gas today at my normal gas station this morning and the car already seems to be running better. I'm hoping its not wishful thinking. We shall see!
Old 10-02-2012 | 12:49 AM
It is wishful thinking. Have the codes read!
