2003 ion broken clutch pedal ?!?!
Old 05-12-2017 | 04:37 PM
03ion6491's Avatar
Exclamation 2003 ion broken clutch pedal ?!?!
Just bought a 2003 Saturn Ion 2.2litre with a 5 speed and the clutch master cylinder rod has broken threw the plastic clutch pedal...I need the new pedal assembly with the bracket...my question is does anybody know what the part number is for sure I believe it's going to be part number GM#15274047...
Any body know where I can purchase this part other then the dealer because they want $295 for the new plastic pedal...is it just me or does that seem rediculous for some plastic ? I can't seem to find it anywhere else other then the dealer, dealer part only ??
Thanks for the help
Old 05-12-2017 | 08:04 PM
19bonestock88's Avatar
I think ZZPerformance sells the ion clutch pedal; shop under the "ecotec" category, as they also serve markets for Cruze/Sonic, Cadillc ATS, and the old 3.8 V6
Old 05-12-2017 | 08:45 PM
03ion6491's Avatar
Yeah I saw the one on zzp was just skeptical about it fitting a 2003, in one of the reviews on that clutch pedal on their page , soneobe said the had to heavily modify it to get it to fit ?
Old 05-13-2017 | 04:28 AM
Bones do you have a dealer pedal or a zzp in your 04 IRL?
And would the RL be the same? Too lazy to look it up
Old 05-13-2017 | 05:08 PM
The pedal in the redline *should* be the same as the regular Ion, but I don't know if it's 100% the same between the coupe and the sedan...
I've got the original pedal, which should in theory be replaced, I kinda made a ghetto fab solution to the issue I was having with my pedal
JoshKava
07-13-2011 08:53 PM
GorgeGeorg
12-10-2010 09:48 AM
07-04-2010 11:40 PM
Jerm088
05-21-2009 12:17 PM
nhughes18
03-06-2008 11:45 PM
