Brake problem! What could it be?
Old 11-21-2023 | 06:37 AM
Buckeye_Guy's Avatar
Default Brake problem! What could it be?
2007 Saturn Ion with 2.2 liter engine. Daughter's car.
Three weeks ago I replaced the front and rear brake systems: all new rotors, drums, calipers, brackets, pads, shoes, etc. The only thing I did not replace were the rear wheel cylinders. They were not leaking and looked O.K., so I didn't mess with them.
I bled all four brakes when I was finished. Daughter drove it for a week. Brake light was on the whole time, for some reason. She also said the brake pedal felt "spongy."
So last weekend I AGAIN bled all four brakes. Brake light went out! 😇 But I must admit, the brake pedal still felt a bit spongy to me.
Yesterday she told me the brake pedal went to the floor a couple times when she tried to stop. I checked out her car. The brake light is back on! 😡 Brake pedal feels spongy. Fluid level looks fine.
I am not sure what the problem is at this point. Could there still be air in the sysetm? Or might the master cylinder be bad?
Old 11-21-2023 | 09:32 AM
How do the brakes feel with the parking brake applied? Does the parking brake work correctly? A newer car with antilock brakes often has special bleeding procedures that require a scanner not a code reader to bleed the system. I have a factory service manual set for a different series of Saturn. We will be able to help you.
Old 11-21-2023 | 06:28 PM
Thanks for the response. I haven't tried the brakes with the parking brake applied.
Does this car have ABS?
Old 11-21-2023 | 09:16 PM
oldmarine's Avatar
If you have an Ion 3, you probably have ABS. Check to see if you have an ABS light when you first turn the ignition on, located just below the coolant temperature gauge.
Old 11-23-2023 | 01:04 AM
DropDead's Avatar
Brakes in the non abs ions are a bit softer feeling than abs ions. But pedal shouldn't be going to the floor.
Old 11-23-2023 | 12:48 PM
jamnar's Avatar
Assuming drum rear brakes (since you said wheel cylinders) have they been adjusted correctly?
If they have not then the spongy pedal could be from the slack from them being too loose.
Old 08-07-2024 | 07:53 PM
That1dude's Avatar
What do you mean by "adjusted"? I just replaced two wheel cylinders on rear drum brakes on an 07 Ion-2 2.2 and didn't do any adjusting.
Old 08-08-2024 | 05:43 AM
jamnar's Avatar
The OP stated that they replaced "new rotors, drums, calipers, brackets, pads, shoes, etc.".
Replacing drums and brake shoes requires readjustment of the brakes for proper clearance.
If all you are doing is replacing the wheel cylinders (which the OP had not) then theoretically you don't have to readjust.
I say theoretically because it is typical to have to adjust the brakes to get some clearance in order to be able to remove the drums before you can replace the wheel cylinders.
If you didn't have to do that then they were most likely too loose to begin with.
Old 08-08-2024 | 07:39 AM
That1dude's Avatar
Of course! I was thinking the wheel cylinders themselves had to somehow be "adjusted". You make perfect sense. I just wasn't thinking right
Old 08-08-2024 | 11:51 AM
Old post, guys
2008vueXE
07-01-2024 07:34 PM
kdrifter440
Saturn Aura
05-15-2023 09:13 PM
tvtn
07-09-2021 05:21 PM
vicgac
06-12-2012 08:22 AM
bacobra777
11-15-2010 05:24 PM
