Rear Defrost...2007 Saturn...
Old 07-21-2014 | 08:36 AM
SolomonMan's Avatar
Default Rear Defrost...2007 Saturn...
All,
In the last year or so I have noticed my rear defrost is not working/or not working as well as it once did.
I am looking for the test procedures on a 2007 Saturn ION rear defrost.
The light powers on when pressed in the console area.
I am guessing the procedure is probably something like;
Check for voltage at the window plug and check continuity in difference areas of the window....but not 100% positive. I know there are repair kits out there....but not sure the whole procedure etc.
Anyone ever troubleshoot a rear defrost?
Thanks,
Chris
Old 07-21-2014 | 08:46 AM
You probably need to take a close look at the contact tabs and make sure they haven't come unglued from the glass. I've seen that happen. If they're okay, you need to check each "wire" across the window for breaks or missing segments. I've seen repair kits for them if that happens, but I can't recall where at this point in time.
jordan83
Saturn Aura
03-15-2016 11:04 AM
danielpattonjr
03-28-2013 10:51 PM
TRoop
02-24-2013 11:29 AM
redvue
12-02-2011 12:19 PM
JonJon3281
11-10-2006 02:26 AM
