Saturn ion 2003 Manual no crank no start
Old 10-23-2019, 11:13 PM
Kaseykurz's Avatar
Default Saturn ion 2003 Manual no crank no start
SOS please help....
I have a 03 Saturn Ion Level 1 and for months my check engine light has been intermittent and after letting my car set all night a week or two ago when I came back to the car the next morning it would just need a jump. After a couple days of this I let it sit all night and then the next morning it would not even jump start. Every day since it has not cranked or started even after I replaced the battery.. the lights, radio and cigarette lighter all work when I turn the key. The fuel pump doesn't kick on and the fuel gauge doesn't work. The back part of the ignition switch was replaced today not the Tumbler but the actual switch.. still no crank or start. No fuel pump or fuel gauge but the radio and lights work. The car still displays "Pwr str service" as well.
Old 10-24-2019, 07:27 AM
DropDead's Avatar
Security light on by any chance? Corroded grounds maybe?
Old 10-24-2019, 04:06 PM
Kaseykurz's Avatar
Maybe I have some rust in the trunk pretty bad. I had someone replace the ignition switch (not the lock cylinder or tumbler). Just the switch. And now my passlock is on so I need to do a relearn I think then maybe after taking care of the terminals hopefully I will have better luck.
Old 10-24-2019, 11:20 PM
DropDead's Avatar
You know the ignition is under recall, right?
Old 10-25-2019, 12:22 AM
Kaseykurz's Avatar
Yes last year I even had some starting issues around this time of year and imediately had the recall fixed where they gave me different keys.. I am going to try and use a blow dryer tomorrow or next day to see if that helps because that seems to be a thing that solved this type issue.
Old 03-09-2022, 03:48 PM
Jonny8412's Avatar
Originally Posted by Kaseykurz
SOS please help....
the same thing happened to me with my 2005 what was the fix for this
Roberta Schultz
02-20-2020 11:34 AM
Kyle West
01-04-2019 04:12 PM
Saturn SC2 guy
08-13-2017 04:13 AM
Davatk
02-06-2017 11:52 AM
Furious
09-12-2010 12:27 PM
Quick Reply: Saturn ion 2003 Manual no crank no start
