Saturn ion cv axle
Saturn ion cv axle
Hey everyone, I’m replacing a cv axle on a 2006 Saturn ion. I got the axle out with ease however I noticed that the side that’s going into the transmission has a shaft on it and the new axle I have does not. Does anyone have any tricks to remove that shaft without damaging the rubber part of it?
Photo for reference
Photo for reference
Since Ions are only front wheel drive, you do not have a transfer case. You have only a transaxle, your Ion is front wheel drive. It is extremely possible that a bad cv shaft is causing a vibration upon coasting. Does it vibrate under acceleration? It may be a motor mount that lets the engine contact the subframe under compression.
