Saturn Ion problem
Old 10-04-2009 | 01:42 PM
HPR's Avatar
HPR
Question Saturn Ion problem
I have a Saturn 2004 Ion that moves without stepping on the gas.
It idles at 700rpm in park but does not drop when shifted into any gear. It will even go uphill in gear without pressing the gas pedal. I took it to Saturn and they replaced the Idle Air Control Valve but it still has the problem. They also reprogramed the PCM per bulletin 04-06-04-029A....HELP
Old 10-04-2009 | 06:50 PM
HPR
Junior Member Join Date: Oct 2009
Saturn Ion problem
"I have a Saturn 2004 Ion that moves without stepping on the gas.
It idles at 700rpm in park but does not drop when shifted into any gear. It will even go uphill in gear without pressing the gas pedal. I took it to Saturn and they replaced the Idle Air Control Valve but it still has the problem. They also reprogramed the PCM per bulletin 04-06-04-029A....HELP"
At what rpm would you like to see it idle at when in drive? 700 RPM in drive sounds a bit low to me.
Old 10-04-2009 | 07:01 PM
Sounds like pure bullchit to me.
Old 10-04-2009 | 07:14 PM
700 RPM seems like a reasonable idle speed when in gear. If you have a problem with the car going without stepping on the gas - try stepping on the brake, it should work
Old 10-04-2009 | 07:19 PM
The brake ........... he never thought of that.
Old 10-05-2009 | 06:00 PM
Sounds like something lowsaturn should handle ..... ya think?
Old 10-05-2009 | 09:13 PM
lowsaturn lowsaturn whereforartthou lowsaturn?
Maybe its a turbonator issue....I thought the turbonators on the Ions were pretty solid but i guess anything's possible
Old 10-17-2009 | 11:17 PM
I should delete this thread but everyone must see how some people are to stupid to drive etc.
bartelbjones
11-22-2020 03:11 AM
buzzchamp33
11-01-2014 12:54 AM
mike82
07-12-2011 10:01 AM
ptgee
09-20-2009 10:47 PM
RjION
Sights N Sounds
03-14-2009 09:10 PM
