Water Leaking Onto Floorboard,,,,HELP
Old 08-24-2008 | 06:18 PM
c.partain's Avatar
Hey guys, got a problem and need some help. I have an 06 Ion that seems to leak water under the passenger side dashboard (under or behind glovebox). Seems to occur when I have the air conditioner running. I live in Louisiana so there is no possible way I can function without the AC. Can someone please give me a little insight to my problem. Thanks for the help.
Old 08-25-2008 | 08:52 AM
TheEngineer's Avatar
you either have a bad heater core, or a bad line comming into the heater core. Alot of times those lines jsut get clogged. But this is something that can be a PITA to repair by yourself since the location is difficult. I suggest bringing it to a mechanic that you trust to repair it
Old 08-26-2008 | 09:50 PM
Clogged A/C drain from the evap ..
Old 08-29-2008 | 12:12 AM
c.partain's Avatar
How would I remove the clog from the evap drain?
Old 08-30-2008 | 05:31 PM
Take it to someone that knows what they are doing. If it''s under warranty can you think of what to do?
spoolnaround
05-25-2011 09:51 AM
casacano
09-06-2009 06:32 PM
medic2434
06-17-2009 09:13 PM
gregl
07-12-2008 11:45 AM
KELLYM
06-29-2005 07:11 PM
