2000 ls sedan
2000 ls sedan
I have a 2000 ls and having a/c trouble. A/C was working fine last night and today would not come on. I checked relays, fuses, freon, all good, electrical power is good to compressor. The clutch is free but not spinning. Is this a compressor problem or a clutch problem? Thanx
If it's A/C: The first thing you need to do when working an an A/C unit is to put a set of gauges on it. Your welcome.
I'll ask one question..............does the heater and blower motor operate?
Take a heavy gauge wire, and hook to the positive (+) side of the battery. Start the engine, and carefully touch the wire to the clutch control wire on the compressor. Does the clutch engage, and turn the compressor ??
