2002 LW300 dies after ten minutes.
Old 03-05-2008 | 01:22 AM
jlook95's Avatar
We have a 2002 LW300, 6cyl., fully loaded, 104K miles.
Recently, the car started dying at randome times. Usually while not moving, like in a drive-thru. Then it started dying while moving, like on the highway!!
Money is tight, so we had a guy look at it. He thought it was the fuel pump. We replaced it, no luck. Then he put in a new fuel filter and swapped relays. Again, no luck.
As of now, the car starts, runs for 10 minutes, then just shuts off flat. No noise, dies, power completely cut. No "chug, chug", just flat quiet. We wait 5-10 minutes and it starts, then dies after about 5 minutes. Something seems to be overheating, like a relay or something, but we can't figure out what.
Tried replacing the fuel pump/filter and associated relays and nothing has changed.
2002 LW300, 6cyl., fully loaded. 104K miles
Hoping that other Saturn owners have had a similar problem with their cars with this kind of mileage. Edited by: sw2cam
Old 03-05-2008 | 01:26 AM
jlook95's Avatar
Also wanted to add that we've checked the alternator, starter, ignition switch. All are good.
Edited by: sw2cam
Old 06-09-2008 | 05:11 PM
mikederocher's Avatar
Had the same problem once. It was the ''crank position sensor''. It''s one wire and one bolt. About $100 from Saturn. It''s a sensor, but the computer will show no code when it goes bad.
When it happened to me, it would run fine then shut off for no reason. It would crank and crank and then start after 10 min. or so. Never had problem again after replacing the crank position sensor.
one more thing... mechanics can never find it because it throws no code to the computer. It runs fine for them when they have it, but they rarely fix it.
2008vueXE
07-01-2024 07:34 PM
mvila0909
07-08-2012 02:07 PM
gostmn26
04-11-2010 02:59 PM
tomsw21999
03-18-2010 10:56 PM
birdy1
12-29-2007 10:04 PM
