2003 Saturn L200 - 5 Speed
Old 01-14-2012 | 08:53 AM
tim's Avatar
tim
Default 2003 Saturn L200 - 5 Speed
Anybody had any alternator/voltage regulator problems? Replaced twice in the last year and a half, and a new battery. Last night driving home at night started losing interior lights for a second and they came back for a bit then it happened again all at random. Then when braking it did it again. With the car running meter shows 15.3 volts at battery (with alternator connected), disconnected the alternator battery reads drop to 13.8 volts. Anybody got any suggestions? (Not using GM but after market alternators.)
Old 01-14-2012 | 11:11 AM
Check battery cables make sure they are clean and tight. Cut back a bit of covering on the positive cable to be sure it is not corroded. Have the charging system checked with a load tester to find out if all is working up to specs. Same with the battery load test it. Myself, I will never buy hard parts from CheckerAdvanceO'reillyZone. Junk, all junk.
stratman3
07-13-2018 06:36 AM
kaushal402
02-04-2017 10:44 PM
kaburns519
06-03-2015 01:58 AM
phxpilotmkv
11-27-2010 08:40 AM
stratman3
11-27-2008 10:04 AM
