2k rpm idle code p300 01 L200
Just finished the head rebuild/timing chain replacement on my buddies 01 L200 2.2l.. started it up and Im getting an idle at about 2k rpm. If I give it some gas it goes up and drops slowly back down to the 2k rpm range.. I put the scan tool on it and got a code p300 multiple cyl. misfire. The fan also runs non stop but if I clear the code while the car is running it turns off and then back on as soon as it throws the code again. Getting an ign timing reading of about 8 deg. advanced at ~2krpm. Im assuming with the fan being on its coolant temp sens related but that still doesnt explain the code. anyone have a pic or description of where the cts is? or have any idea where I should start with troubleshooting? new to saturns no idea where to begin. thanks in advance for replies. Edited by: sw2cam
mtdanielsen
01-10-2013 08:55 AM
mikes 1994 z28
08-09-2006 09:08 AM
