’98 s-series wagon
Old 12-06-2006 | 01:48 PM
soonersaint's Avatar
My 1998 standard trans. s-series is idleing high in gear and out of gear (up to 2100 RPM's) It also hesitates when trying to accelerate. this happens mostly at beginning of gear change when RPM's are low.It feels like it's missing. I have not taken it any where and it is my families primary car. I am tight this month so any advice would help.
Saturn...best car I have ever owned![img]smileys/smiley4.gif[/img]
Old 12-07-2006 | 02:09 AM
S-Turn's Avatar
Well, I have have no idea how familiar with cars you are, so I'll start with the basic suggestions. If you feel like it's missing check all of the plug wires and make sure the boots are tight on the plug. With some cars i've driven the air cleaner was so dirty that the car actually felt like it was lagging real bad, so mayble checking the air filter isn't a bad idea. My last suggestion is to double check the vacuum hoses since the car will run like crap if these aren't connected. There's many other possibilities, but i hope this helps![img]smileys/smiley1.gif[/img]
Old 12-07-2006 | 05:28 AM
High idle on S car engines is most often attributible to either a bad ECTS + connector (Engine coolant temp sensor), a vacuum leak, or just a filthy sticking throttle body.
Start with throttle body cleaning. When done, spray throttle body cleaner around all vacuum connections, and especially at the the intake manifold gasket and the throttle body connection. If rpms change, you've found your leak.
If problem persists, I would replace ECTS and connector (connector is Saturn only part).
Keep us posted
Derf
Edited by: derf
Old 04-22-2007 | 10:47 PM
Keep us posted
Derf
Thats the ticket.
mjulia31
10-13-2008 06:08 PM
soxman
04-12-2008 04:13 PM
redcannon
06-10-2007 05:11 PM
elnino
06-05-2007 10:01 PM
barristo
08-18-2005 12:46 PM
