brake help
Old 02-19-2008 | 06:21 PM
rnjones's Avatar
</>I have a strange brake issue. Replaced frontpads 4 months ago. Everything has been fine. This past weekend the right front caliper lower outside edge started rubbing the inside of the wheel. I have completed the following. Loosened caliper and retorqued, Re-lubed guide pins, smoothed area on caliper. Changed wheel with one from left front, replaced wheel bearings year ago. Checked wheel for play, its nice and tight. I noticed clearance on left side between caliper and wheel about 1/8". Much less on right side but not sure why. Problem back two days later. Any suggestions?</>
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
</>Edited by: rnjones
Old 02-19-2008 | 08:29 PM
groingo's Avatar
Did you check the brake pad itself to be sure it is firmly attached to its steel backing, they occasionally come un bonded.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-47";
urchinTracker();
Old 02-19-2008 | 09:41 PM
rnjones's Avatar
</>Yes I have. You can see where the wheel and caliper actually are rubbing against each other. I can't find anywhere to adjust for clearance. &lt; =text/&gt; _uacct = "UA-939292-47"; urchinTracker(); </>
< =text/>
urchinTracker();
asbennett
02-25-2017 10:09 AM
Southsider
10-13-2013 12:54 PM
Epic
04-19-2011 09:10 AM
Shadowman750
03-28-2008 10:50 AM
CoastGuardGuy
06-27-2006 01:25 AM
Quick Reply: brake help
