Engine Trouble
Old 05-12-2013 | 04:36 AM
nsibert's Avatar
Default Engine Trouble
Hey,
I have a '02 Saturn L200 2.2L with 130,000 miles. My wife drives this carmost of the time. So about a couple of days ago she told me about a noisecoming for the engine during startup. I checked it out and it sound like alifter sticking. I only hear it during startup and for about the first 5-10minsof driving then it goes away. So I am assuming that the oil is getting movedaround and quieting the sound. I am thinking that this could be a bigger issuewith the timing chain. I have read some articles about the timing chain issues onthis particular engine model that has caused lots of grief.
Any ideas of what direction I should go to further troubleshoot this issue?Not sure if it solely a lifter/rod issue or the timing chain. I am planning oncalling a dealer to check out any recalls. Thanks
Old 05-12-2013 | 08:28 AM
First thing to do is check your oil level and make sure it's full. If so, I'd use a little Seafoam in the crankcase to see if that helps. When's the last time you changed the oil and what weight are you using. If 5W-30, then I'd recommend stepping up to 10W-30.
Old 05-12-2013 | 11:05 PM
10W30 is what my '02 L200 runs on ...
Old 05-13-2013 | 10:36 AM
crimsonandblue's Avatar
Could be a numbers of things but over time and with wear parts do not keep their original shape (small components will warp within thousandths of an inch over the life of the car) which is basically the reason why old cars don't run like new cars. It could be that until the oil warms up it's causing some kind of interference. Even a thousandth of an inch can cause small components in the cam and valve train to rub and cause a suspicious noise.
Old 05-13-2013 | 11:31 AM
nsibert's Avatar
Oil level was fine. I did an oil change and added some Seafoam. The noise is not as loud. But I can still hear it during start-up.
Old 05-13-2013 | 04:50 PM
Hopefully, the SeaFoam will eventually quiet your troubling noises ...
Old 05-14-2013 | 04:07 AM
nsibert's Avatar
I called a dealer and found out that my car is not under warranty for the timing chain. Bummer....I am hoping the Seafoam works.
Old 05-14-2013 | 09:12 AM
If it was the timing chain, Seafoam would have had no effect on it at all. You can officially rule that out if the noise isn't as loud as it was. It sounds valve train related to me.
Old 05-16-2013 | 04:34 PM
nsibert's Avatar
Now the sound is getting louder and lasting longer. I am probably going to take it into a shop to at least have it diagnosed
Old 05-16-2013 | 06:41 PM
Please let us know the result of the shop visit/diagnosis ...
Resshin
08-01-2019 07:11 AM
mcgyver
09-26-2006 11:05 AM
ray3483
05-09-2006 01:39 PM
waldowarlord
04-13-2006 04:54 AM
one day
01-20-2006 03:58 AM
