L200 Overheating
Yea for sure, I told him to keep me updated if he took it to the dealer or found someone that could figure it out. I will keep you posted as well if anything is figured out. but yea I didn't like giving up.
That's a pretty cool little story though. Good times when things finally click and your like OHHHHHH YEAAAAA lol. well thanks for all the replies ppl! till next time...
Leaves Packed Between Radiator/Condenser Overheat!
Hey guys and gals, I am a technician at a california shop and we got a 2001 Saturn L200 2.2L in the other day. Vehicle came in overheating. The upper radiator hose was hot to touch up at the engine but not hot towards the radiator. the lower hose where the Thermostat was not hot at all. so I recommended a T-Stat.
Replaced that T-stat and no cure. So I took the T-stat out and Made sure it was opening (It does at 200 degrees) So I left it out and was checking for pump flow. I couldn't really see any volume of coolant being pushed through the system so I suspected a bad water pump.
Replaced the water pump after ordering the special J-tool and still couldnt really see any good flow. So I decided to take the radiator out and make sure it wasn't plugged, ran water through it seemed fine to me but to make double sure I took it and had it flow tested. came back good.
Put the car back together and I still have the same lower radiator hose is cold at 220 degrees and the Upper hose is Hot. So I have a New water pump, New T-stat that I have reconfirmed opes at 200 It is an OE 180 thermostat. I cannot figure out for the life of me what else could be wrong at this point....
ANY IDEAS!?!?!?
ANY IDEAS!?!?!?
Another overheating issue with the Opel 4-cly. engine in the L200 cars may happen during radiator replacement. After re-filling the new radiator, there were air pockets inside the coolant jackets of the engine. These air pockets may prevent cooling and lead to overheating. Try to expel the air pockets by allowing the engine to idle with an open radiator cap until all pockets are full of coolant.
