saturn wont start
saturn wont start
I need help with my 2000saturn saturn ls 2.2 twin cam it wont start has spark but it is yellowish and has fuel pressure is good but it wont start changed the plugs and crank sensor also changed the collent senor and fuel pressure reg i dont know where to look now
Is the yellow spark at the plug or directly off the coil wire? If at the plug, then maybe the plugs are not the correct ones for your car, but highly doubtful. If grounding a coil wire shows the yellow spark, I'd try replacing it and see what happens.
