Slipping tranny?
Old 07-04-2008 | 07:45 PM
Stefi's Avatar
Hey gang, newbie here. Gotta a problem with my 2002 L200 automatic. It feels like a slipping tranny. When I pull out in traffic and give it gas, it revs but won''t go. If I let off the gas it will go in gear. It seems to happen in every gear. Thoughts??
Old 07-05-2008 | 02:32 PM
Stefi's Avatar
OK, my boyfriend took it for a test drive and he said it''s not the tranny, something''s bogging down the power causing it to rev just to keep going. MAF or oxygen sensor perhaps. He''s going to change the fuel filter, too. Changed the oil, oil filter and air filter today as routine maintenance.
Whaddya think?
Old 07-05-2008 | 05:59 PM
IVI4ssacre's Avatar
if the tranny isn''t slipping i bet the cat converter is clogged. very common with the 2.2 Lseries.
Old 07-09-2008 | 09:30 PM
Stefi's Avatar
Thanks, we''ll try that this weekend!
Old 07-12-2008 | 05:47 PM
Stefi
Just a quick question here ... does your L200 have traction control, and is the light for the traction control lighting up?
Old 07-13-2008 | 06:31 PM
Stefi's Avatar
Yes, it''s got traction control but the light isn''t coming on. We took the upstream oxygen sensor out to see if the cat was clogged, and it definitely ran better (but loud!). So we took the cat off today and are replacing it. It was tough to get off, we had to cut two of the bolts off on the rear flange.
Old 08-02-2008 | 10:52 AM
Stefi's Avatar
New cat on, fixed the problem. Catco from Summit Racing. Thanks for the info!
dkriz
03-16-2018 01:31 AM
junior
12-02-2009 07:34 AM
boogawooga
05-24-2006 11:17 AM
HeatherP00
11-08-2005 04:35 PM
iw433
03-24-2005 09:23 PM
