Still need help
Old 05-20-2008 | 06:06 PM
cordytess's Avatar
[img]smileys/smiley7.gif[/img] Okay, I have replaced the fuel filter, the fuel pump, O2 sensor, MAP sensor,Throttle body sensor, coolant sensor, new wires, new plugs,new PCV,battery and alternator tested fine. I have a 1998 Saturn SL and I am having a little problem starting the car, it does eventually, and a bit of a problem with hesitation,The Check engine light is on and the code again was lean fuel. I don't know what to do next to help these problems any suggestions would be great.
Old 05-20-2008 | 06:44 PM
TheEngineer's Avatar
i used to have some starting problems with my car as well and it was mostly when it was cold and it was intermittant. (alot of times when the car sat for the day.) there was two things i did to try and improve it and i have yet to have problems with starting. And that was these two things:
- starting only using 89 octane instead of 87
- put in 'isoheet' in order to try and remove any water and condensation that might have built up in the fuel lines. you can get this stuff anywhere.
RjION
Saturn Astra
12-29-2010 10:02 AM
OceanArcher
Saturn Aura
10-24-2010 09:10 AM
guitback
09-17-2010 02:02 AM
bountyhunter
01-05-2009 08:48 AM
caldi
09-18-2008 05:06 PM
