2002 Saturn L300 Starting
Old 05-16-2006 | 10:11 AM
deanrp's Avatar
I come out of the house and the car starts fine. If I drive a couple of miles and stop the car it will not start. The engine turns but will not start. If I spray starting fluid in the air cleaner the car will start and run fine. It seems to be intermittent because yesterday I had no problems. I never seem to have a problem when the unit is cold but only when I drive it a couple of miles and shut it off.
Old 06-01-2006 | 03:55 PM
Dean.....................are you getting a SES light by any chance?
Old 06-01-2006 | 04:00 PM
deanrp's Avatar
I found the problem - The crank sensor was breaking down when the engine got warm. I had an error code for the speed sensor andon the third day the auto would stall at a stop sign. The crank sensor fixed everything.
Old 06-01-2006 | 04:30 PM
Outstanding..................happy you found the problem. A throttle postion sensor can cause the same sort of thing. So if it happens to you in the future you have a couple of things to look at.
Old 06-02-2006 | 05:31 PM
deanrp's Avatar
Saturn is having problems with the crank sensor.
Old 06-03-2006 | 12:16 AM
No more than any other car on the road.............Parts fail.
rogers
11-25-2014 01:53 PM
chblanx
06-07-2012 06:11 PM
MLC1990
03-06-2011 02:16 PM
jsdub525
08-27-2008 05:39 PM
mpl1954
Saturn L300
07-06-2008 10:06 PM
