not running good
Old 03-17-2007 | 08:25 PM
billyjoe's Avatar
92 saturn was running good. abuot 20 miles in to my drive started to run rought then quit runing.when it starts up in wont run less you theter the gas.idels up and down.wont run smouth.any ideas.
Old 03-17-2007 | 08:29 PM
billyjoe's Avatar
any boby need 92 saturn parts good 5speedtran.body partsgood4good doorspowerwindows.
Old 03-17-2007 | 09:09 PM
Clean EGR valve and the ports it connects to.
Old 03-18-2007 | 01:33 AM
ducky's Avatar
Have you checked the engine coolant temperature sensor (ECTS), that's prone to cracking? The symptoms of a failed coolant sensor would either be running rich and idling high or fails to run and stalls unless blipping the gas pedal. The original coolant sensor is made of resin and very problematic unless replaced witha newbrass sensor.
Old 03-18-2007 | 02:41 PM
billyjoe's Avatar
thank for info on 92 saturn.billyjoe.
Old 04-18-2007 | 02:06 AM
Why did you post about a SL in the L300 forum?
quadcoupe
02-25-2015 07:27 PM
woodsheder
06-12-2012 11:33 PM
Irish Pride
08-25-2011 12:12 AM
kbankovi
02-26-2007 03:07 PM
dgi007
Audio/Visual Electronics
04-02-2006 06:08 AM
