Saturn Outlook 2008 XR Glove Box light bulb
I would like to replace the Glove Box light bulb, but can't find its location. Could someone please help me and send information where this bulb is and how to replace it?
Br, Ella
Br, Ella
Not exactly what you asked for, but apparently the switch is problematic and will stick in the on position and drain your battery. Burning out that bulb in two and a half years was either a fluke or switch has been sticking in the on position leaving the light on.
You can loosen up the switch with silicone spray or you can leave it with a burnt out bulb in it so that it cannot drain your battery. This is a BS solution but likely better off in the long run.
Glove Box Light - SaturnFans.com Forums
