Tsb
Tsb
Is there any way for me to tell if a TSB has been performed on my Outlook? I'm looking at the reflash... which is TSB # 08-07-30-022A which has to do with the reflash of the transmission shift points. I am actually the 3rd owner, so I have no idea whats really been done.
I get really bad gas mileage so I wonder if I need this done... Can a dealership just look it up and tell me if it's been completed?
Thanks to anyone who replies!
Thanks! I just made an appointment to take it in because it looks like I need the update. I'm in central michigan, so mostly flat. I averaged 16.82 mpg on 14,433 miles driven in 2013. Ratio of 50/50 highway to city driving...
Seems like it should be higher than that. Am I wrong? I am the 3rd owner now since it was new so it's tough to tell whats been done to it as far as the TSB's go...
Cat, stop in the new member area and introduce yourself. When done open the USER CP and add your first name, location, and year/model to your "signature".
First you did not tell us the year or model "Outlook" your driving. AWD 3.6L should be around 18mpg. A FWD 3.6L should be around 19 mpg, and all of that depends on many variables.
So I have a 2007 XE that's FWD 3.6. Had it at the dealer today, TCM needed an update. But good thing I had it in, cause they scanned and found the code that says the timing chain is stretched and are replacing all of that under warranty.
