02 sl1 radio issue
02 sl1 radio issue
i need the pin location numbers on the factory radio connector for a 02 sl1 with built in cd player, i already know what colors im looking for, i just need the pin numbers, i.e. b1, b2 a1, a2 those numbers only for the constant orange and the ignition yellow
Chilton (among others) makes a Repair Manual for your car, and it is stocked at most after-market auto parts dealers. About $25 bucks last time I checked. It has a great electrical section which should answer all your questions about the connector wiring.
Check this post.
https://www.saturnforum.com/forum/saturn-s-series-sedan-27/2001-sl-2-radio-wiring-diagram-7475/
The CD harness just goes from the CD to the radio, it does not connect to the car harness.
The radio with the built in CD player is the same as for the radio with cassette tape or just the AM/FM radio only. The one that is different is the AM/FM radio with the CD changer. Then there is the same harness for the radio and a separate harness to go between the CD player and the radio.
But here is what you want in a different format.
A4 YEL IPFB-IGN .35
A6 YEL IPFB-IGN .35
A8 BRN LR SPEAKER .80
A9 YEL LR SPEAKER .80
A10 DK GRN RF SPEAKER .80
A11 LT GRN RF SPEAKER .80
A12 BLK SPLICE PACK #2 GROUND 1.0
B1 ORN IPFB BAT 1.0
B3 ORN IPFB-CD B+ .35
B4 GRA IPFB-DIMMER CONTROL .35
B8 TAN LF SPEAKER .80
B9 GRA LF SPEAKER .80
B10 LT BLU RR SPEAKER .80
B11 DK BLU RR SPEAKER .80
B12 BRN IPFB-PARK LAMP .35
IPFB Instrument Panel Fuse Block
The numbers at the end are the wire size in mm.
Top row, left to right B12 - B1
Bottom row, left to right A12 - A1
A4 YEL IPFB-IGN .35
A6 YEL IPFB-IGN .35
B1 ORN IPFB BAT 1.0
