02 sl2 dohc
Originally Posted by 97sl1eddie
Error code P0410 is appearing. Is this an expensive fix? Do I need a mechanic?
P0410 Secondary Air Injection System Malfunction
Usually caused by carbon build up in the AIR system. Remove the tube that connects to the exhaust manifold and clean it out. Cleaning the channel that goes in between the port openings on the flange of the exhaust manifold helps too.
Very easy DIY fix.
Very easy DIY fix.
