1996 SL2 Idles Fast only
Old 11-19-2006 | 05:29 PM
Fireball69's Avatar
NEWEST UPDATE: Problem - engine idles at 2100 RPM and will not drop to low idle. Still has high idle. Throws a P0341 every once in a while.
What I have done so far: Replaced Engine Coolant Sensor and connector, PVC valve (from Saturn), and spark plugs. Removed and cleaned TB, IAC,TPS, and EGR valve.
What do I need to do next? I need to get this car fixed soon.
Thanks
Old 11-23-2006 | 01:29 PM
Fireball69's Avatar
Finially got it. Replaced TB gasket and vacuum lines on PVC Valve, hose from valve cover to intake, added hose clamps to power brake booster vacuum line, and to hose to canister.
It is idleing linke new. Also, transmission is not slipping but shifting hard into second and third. Have replaced the top motor mount last week and purchased both dogbones for the lower end and will replace them today (after Turkey) or tomorrow morning. Will also check the transmission mount when under car. It this fixes all the problems, the great, otherwise it will mean the transmission shop.
dwurz
11-08-2012 09:17 AM
spaz
12-06-2008 05:10 AM
BostomSound
08-08-2008 05:41 PM
paulorlo
09-23-2006 05:35 PM
Lucas
03-11-2006 03:46 AM
