1998 sl
Old 10-18-2009 | 04:12 PM
turbochargedv8's Avatar
Default 1998 sl
i just bought a 98 sl and the ac blows cold but i noticed it doesnt blow as much out the center two vents. is this a common problem and does anyone know what needs to be done?
Old 10-18-2009 | 04:25 PM
possibly an issue with the ventilation control cables?
(Not my forte)
OA should have some good input on this.....
Old 10-19-2009 | 10:25 PM
More likely a dirty evaporator core -- remove the shroud surrounding the A/C (have to disconnect and remove the radio too), then careully clean the coil and remove any foreign debris -- then reassemble
Old 10-19-2009 | 11:02 PM
really? that would affect distribution of air flow???
Please explain, sir....
Old 10-22-2009 | 12:33 AM
The blower forces air through the evaporator core, then distributes to to the inside of the vehicle. When the system is set to "recycle" the cabin air (max cool) the system can draw dust-n- debris off the carpet mats and into (on the ) core, thereby restricting the flow
Old 10-22-2009 | 08:17 AM
well I'll be....
But how does that affect the distribution amongst the vents -- or are you saying the because of the buildup on the evap core, the flow is "naturally" restricted in that manner due to the location of the buildup?
Magicmike
12-07-2006 04:31 AM
mlkmgr
12-05-2006 12:44 AM
amazing_fantasy
06-02-2006 09:56 PM
rottie2
04-13-2006 04:31 AM
buzzin_bob
09-13-2005 02:30 PM
