1999 SL1 Wont Crank
1999 SL1 Wont Crank
Starter, Battery, Alternator, battery cables all brand new and replaced within the last two months.
Car has been starting and running perfect. Made a quick trip to the store last night and when i came out it wouldnt crank. Starter Relay is clicking, dash lights, running lights, fuel pump, radio, door chim, door locks, windows and everything else works fine. The only thing that is not happening is the starter turning. After about 10-15 minutes it started. This Morning im having the same issue. But its been about 2 hours now
Battery cables are fine, everything was replaced within the last two months because the vehicle was burning through starter. Those ones would click though and required beating with a pipe in order to get them to turn. Now it simply wont turn.
Voltage is fine, connections everywhere are fine. I've tried everything i could find on google, here and another fourm. I'm lost. And now extremely late for my first day on the job. 4 months to find a job and now i may not have it =-[
Again, at the risk of asking obvious questions, are you sure the starters are getting wired in correctly at installation?
Also, new battery does not always equate to a functional one with the correct CCA to reliably start the car.
Lastly, was the alternator defective? why was it replaced?
Sounds to me you've either hit a bad lot of starters (are you getting them from the same place?) or (at the risk of stating the obvious) there is a larger issue.
So far today if checked the fallowing-
12v signal to the purple wire ring terminal at the solinoid(Key start) GOOD
12v singal from the battery to the solinoid GOOD
12v singal from solinoid to the starter itself GOOD
NSS clean tight and wires are intact (shouldnt be that though because the soinoid is getting a start signal. right?)
Every and all connection from the igniton cylinder all the way to the starter relay, to the starter, to the battery, to the fuse box, everything. GOOD
I dont know where to go from here. This car has been amazing its last 174,000 miles! This and the previous starter issue are the only ones this car has had in its 13 year life. Family bought the car brand new and its always been well maintained. Thanks for any and all help!
Ima say the same thing about pepboys. I got my starter from them and when I pulled the motor out I found that the bolts that held the starter motor in place were backing out from vibration and the motor was about to plop off. Fixed it myself cause I didnt wanna deal with them
Any rebuilt/reworked/refurbished starter can suffer from problems you all have mentioned, especially if the person(s) doing the work are less than attentive to the proper procedures. Like Octavious says (in effect), ..."If you want the job done right the first time, you better bloody well do it yourself".
