1999 SW2 stalling problem
Old 08-15-2010 | 04:09 PM
sirpjmud's Avatar
Question 1999 SW2 stalling problem
1999 Saturn SW2 stalls out after warming up and will not restart until cold again. Also very high RPM when running. Changed fuel filter but still same problem.Could this be the crank position sensor? If so where on engine is sensor located? I have looked and can not find it. Feeling stupid.
Old 08-15-2010 | 06:45 PM
The crank position sensor won't normally be temperature sensitive, but the engine coolant temp sensor definitely would be. Try changing that first
Old 08-15-2010 | 10:36 PM
hoseppi's Avatar
10-4, a defective CTS would definitely cause hot start problems. Make sure the connector is clean.
Old 08-16-2010 | 09:28 PM
sirpjmud's Avatar
replaced CPS today and it seems to have solved the problem.
mascencerro
01-23-2013 05:06 AM
tfg11199
10-17-2009 10:44 PM
JAFO1
Engine & Internal
07-09-2008 09:19 PM
jennmcayer
08-23-2007 12:09 PM
jillowolf
01-14-2006 09:51 AM
