2000 SL1 not cooling
#31
Hope those connections are secure and insulated. Glad to hear you are up and running.
Did you measure across the switch -- if it is bad it will read as an open circuit
In other news, added dye and could not locate any leaks in system other than the low pressure port itself. It's the only leak in the system.
Had the system evacuated --- even though low side pressure was high enough to keep the switch closed, when evac'd only 0.11 lbs of refrigerant were actually in there -- i guess the rest was air...the system holds 1.5 lbs...
Service port replaced, system recharged, all is well -- my compressor is actually fine, though the bearings are getting a little noisy. Hey, its 14 years old....
I would highly recommend an evac and refill after you sort out the switch problem.
______________
Also, be aware that it also could be a wiring issue betw the switch and the PCM or the switch and the A/C relay, no?
______________
#32
Oh I already did a evac on it, I never charge a system without pulling a vacuum!
Ok now for you guys to laugh...so my old compressor which was shot...when it went, it blew a fuse...I checked everything (relay included) except one stupid 10 amp fuse lol. Now I undid my jerry rigging and am up and running correctly...the pressure switch was actually good, thank goodness...that would have cost me $30. So all is well with me now .
