2000 SL2: Check Engine Light
My check engine light came on and I went to get it checked at a Saturn dealership. They said I needed to replace the EGR valve, Coolant temp sensor & connector, and the thermostat.
I was wondering if any of these are absolutely necessary, or if I can test to see which one may be the real problem- I don't trust them since they also said I needed spark plugs and wires needed replaced and I just had those done less than a year ago.
Thanks.
Thanks.
i totally agree with you thisto." when you say i dont trust them "the dealer"
i no the feeling been there two two questions for you how does the car run?
and how if you no. how? did the tecnition test a faulty EGR,coolant temp sensor & why thermostat is it running hot?
