2001 Saturn SP1 Won't Start
Hi - I just finished putting on all new wires and they still won't spark.
I tested the voltage at the white wire OF THE 6 pin connector to the ignition module and it's 1.01 volts. It suppose to be 1 volt or less. I also tested the resistance of the same white wire and it's 1.138 ohms. I'm not sure if I had the multimeter at the proper setting.. it set to it's lowest setting. It was either the lowest setting or 200k setting that gave me a reading. The book says that it is suppose to be above 200 ohms.
You still have not indicated if you have performed the spark test at the coils (sigh)
I will infer from the fact that "the new wires will not spark" means there is no spark anywhere.
Change the Crank position sensor. The resistance reading may be in spec, but if the pulses to the PCM are distorted or malformed, NO SPARK.
I was wondering if not using Saturn parts could be the problem. I also found a TSB on ALLDATA regarding the same problem-crank no start. I haven't read the whole thing yet,but it states the cause is "intermittent battry cable or ground connection nay eventually lead to a PCM class 2 caommunication failure". I was wondering if this could be another possible cause in my case?
tikidude
08-30-2014 06:04 PM
2001SaturnSL1
07-24-2011 11:58 AM
