’94 SL-A/C & Radio went out @ same time
Old 11-12-2007 | 10:48 AM
castortroy's Avatar
'94 SL Sedan double over-head cam
A/C and Radio went out at the same time. I've checked the fuses and they're ok. Any way to check where the fuses plug into to?
Any other ideas?
Old 01-06-2008 | 08:09 PM
David1's Avatar
I see in haynes that both fuses are in the interior fuse box - radio and hvac - #1 I would check to see if anything else controlled by that fuse box is acting up - maybe a ground is bad - it's in a tough spot for tracing where the wires go, so that's why I asked if anything else is acting up as it will be a job.
The only common item between the radio and the ac is 1st the fuse box
97slow
10-30-2013 09:57 AM
daysu47
09-17-2008 04:03 PM
mark2patterson
03-18-2008 09:40 PM
castortroy
11-11-2007 12:37 PM
castortroy
10-23-2007 01:52 PM
