94 SL1 Intermittent Stall
Glad to hear your DD is back to DD status!
It's always gratifying to get to the bottom of these things....
If you get the harness from Saturn parts dept, make sure the map sensor you bought is indeed compatible/equiv to the Saturn part.
Derf
Derf
I had a huge smile on my face after solving this one. Thanks again for your help.
The plug in the new sensor fits fine. The problem is the mounting hole. Mine is mounted on the back of the valve cover with long studs. The new sensor is the same shape, but the long holesare square and too small. I may try to drill it or simply return it as incompatible and by a stock one.
