95 saturn sl1 makes grinding noise
I have a '95 saturn sl1 5speed and it has 167,000 miles on it. lately i have been hearing this awful grinding type nosie that is coming from my passenger fron tire i have popped the hood and tried to find it but cant. the noise stays the same when idleing and when im dring any ideas
I believe you are referring to the tensioner pully that keep the serpentine belt tight. The bearing can fail, and it'll make a gosh-awful noise. While you're at it, check the serpentine belt as well. If you see wear and/or dry rot, replace it too ....
Let's see,
I have an 95 Saturn SL1 vin code 8 (SOHC)
What I see and what AllData list for that model is 7 pullies
I have the following :
Crank pulley (at bottom), alternator, power steering, belt tensioner, idler pulley, A/C compressor and water pump
the top center pulley is the idler pulley.
Here is a sugestion...............
Get a long,( really long) screwdriver, or wooden dowel, touch it to a part you think is too noisey and then to your ear lobe and the noise will be transfered to your ear. keep searching till you "find"/ "hear " the noisey part.
They accually sell a steth-a-scopes for mechanics you can buy too !
