96 sl2 engine interchangable with what years?
Old 12-03-2009 | 10:26 PM
Drock's Avatar
If the new motor that i get is a 95 how does the smog hook up? like the egr? and isnt the 95 obdI and my 96 obdII?
Old 12-03-2009 | 10:55 PM
hoseppi's Avatar
The two are identical except the 95 has an extra cts under where the upper radiator hose exits the head. Also the 95 usually comes with an aluminum rocker arm cover. Everything else hooks right up.
Old 12-03-2009 | 10:58 PM
96 is indeed odb II and 95 ODB I. 95 was 1st year for non-vacuum EGR so you're ok there. ODB II has 2 O2 sensors -- manifold and post cat -- so you are covered there -- you just wouldn't plug in the post cat 02 (but keep it in the bung).
95 was last year for 2 coolant temp sensors -- one for the PCM and one for the dash temp gauge. Not sure if signal to PCM coolant temp sensors would get hosed by having gauge hanging off it too (since they did that for 96 on, doubt it is an issue)
Old 12-04-2009 | 08:24 AM
hoseppi's Avatar
It's a 95 motor going into a 96 car. You will reuse the 96 exhaust. The OBDII system is already in the car. The sensors are all the same. The plugs are all the same. I've done it many times both ways because those were the years of the porous heads (oil in the water). It's a little more difficult putting a 96/97 into a 95- only because you have to drill and tap the head for the extra ECTS.When you have both engines out ,you can compare them side by side and remove anything from the 96 eng and install it on the 95 if it doesn't look right. I'm pretty sure the 95 engines were consistant throughout the model year.
blaisa
05-06-2024 11:53 PM
Murph777
03-29-2011 11:40 AM
Saturn_helper
08-18-2010 05:41 PM
Lilchief
Headers, Intake, & Exhaust
08-12-2010 09:57 PM
roastin300
11-25-2007 01:58 PM
