97 sl2 no crank
97 sl2 no crank
I have a '97 SL2 DOHC that does not crank. I have had the battery tested, terminals cleaned, removed and tested starter no change. Checked the purple wire to solenoid no voltage when key turned to start.
Where do I go from here?
Problem solved. Reseated RKE relay and got 12V to the starter, but still no start. Pulled starter for second time and checked it myself. 40 amp would not turn the starter through solenoid but would clamped on motor lead. Back to parts store get starter replaced (3 yr old rebuild). Car starts great
Thanks for your suggestion!!
tikidude
08-30-2014 05:04 PM
Newhampgirl
09-21-2009 06:49 AM
