98 saturn sl with bad motor shake
Old 01-07-2010 | 12:40 PM
tonygarcia1990's Avatar
Default 98 saturn sl with bad motor shake
at idle i am getting a bad motor vibration. but while driving the car is fine. I did a turn up and did a fuel injection clean nothing changed. I think it might be the motor mounts but idk? If i put my hand on the intake manifold i rock the motor back and forth. i can see the top motor mount but it looks fine where is the lower motor mount and how do u change it ? thanks for your help
Old 01-07-2010 | 01:25 PM
Maybe your talking about a SATURN SL,SL1,or SL2. If so sounds like your top engine mount
Old 01-07-2010 | 05:42 PM
yes sorry its a saturn sl
Old 01-07-2010 | 10:04 PM
top engine mount (torque axis mount) is a wear and tear item on these s cars. Support the engine from underneath (floor jack + wood to avoid point force and oil pan damage) to take the stress off the upper mount. Remove the three nuts on the studs going through the mount and the two nuts that hold the mount bracket to the car.
Replace with new upper mount. Be sure to use new studs and nuts.
If this does not address the vibe, we'll look deeper.
Old 01-07-2010 | 10:08 PM
thanks alot I will let you guys know
Daddi0
07-28-2011 08:21 AM
tonygarcia1990
01-19-2010 01:01 PM
99 Saturn SL2
08-10-2009 11:19 PM
Secretagent0057
06-09-2008 05:28 PM
geramos
07-20-2007 04:56 PM
