A/C Not Working
Old 05-14-2007 | 06:30 PM
ltufd1802's Avatar
My 92 SL2 has A?C and the switch appears to be on but it does not seem like the compessor is activating and the air is not getting cold. I was wonder what the problemmay be? Thanks
Old 05-15-2007 | 12:13 AM
ducky's Avatar
1-As old as your car is the most likely problem is that freon has escaped from a leak and the source of the leak be found and repairs made including replacement of the filter/drier before even contemplating recharging with refrigerant. Most DIY'ers jump to the store bought recharge cannisters (no R12 available for your model year) in a poor attempt at simple refilling without finding the source of the leak that inevitably leaks out the new replacement refrigerant over a period of time, some leak out immediately while others leak anywhere from a few days to a season.
2-You must realize that your a/c system used R12 Freon and that refrigerant has fallen out of favor insofar as repairing/recharging because R12 is now expensive (no longer manufactured) and difficult to find. Underground markets exists as well as clone brands if you're interested in cooling for just a season or two. There are issues involved requiring consideration ofcosts between retaining R12 as the original cooling refrgerant or converting to the accepted R134a refrigerant.
3-Your old system should be evaluated by a pro with due consideration to how long you want to hold onto your car for assessing the amount of money you want to invest to repair your a/c.
Old 05-15-2007 | 02:58 AM
ltufd1802's Avatar
I checked the wire going to the compressor with a test lightand there is no power going to the compressor when the button is turned on inside the car. Does anyone know what may cause this to happen.
Xanderj13
07-19-2007 10:59 AM
SurferDudeUSA
06-30-2007 01:45 AM
neiby
04-12-2007 08:33 PM
mfunk49
01-27-2007 11:13 AM
sdntive
07-28-2006 07:38 PM
