Can't diagnose
Can't diagnose
Hi All,
I'm new here, so go easy on me. I have a '95 SL1 - Manual. I am having a starting issue that I can't seem to figure out. Here is what I've done and tested so far:
1.) Will only start at WOT
2.) Fuel pressure tested fine
3.) Spark plugs are good
4.) Received EGR system fault code; Replaced EGR valve - didn't help
5.) Replaced MAP sensor - didn't help
6.) Injectors are fine
7.) Cleaned throttle body - didn't help
8.) Compression check showed a little low on cylinder 1, but the others were fine.
Once I get the car started it acutally runs great. It's just getting it started that's a P.I.T.A.
Any help with how to proceed would be greatly appreciated.
Thanks guy!
Nathan
Thanks guy!
Nathan
Thx for the help.
Thanks for the help. The ECTS wasn't the problem. I finally figured out the issue. I took the intake manifold off and took it to NAPA to have them clean it in their heat tank. The cleaning seemed to do the trick.
