check engine light going on and off when......
Old 09-01-2009 | 04:39 AM
bucky katt's Avatar
Default check engine light going on and off when......
i'm running at highway speeds (75-80) and the weather is on the warm side, the check engine light will pop on once in a while, if i drop my speed back to 55 or 60, it turns back off again. i have good, clean oil, a new filter, i change trans fluid and canister filter every 20,000 miles or so it has a new o2 sensor, new plugs and wires and the egr only has about 40,000 miles on it as well. the car isnt over heating and this happens whether the a/c is on or off. where should i start looking next?
Old 09-01-2009 | 06:48 AM
read codes and post
Old 09-01-2009 | 02:24 PM
saturnsdn's Avatar
what kind of plugs are you running-sounds like you might have a misfire going on but like derf said if you can find out what codes are being thrown
Old 09-01-2009 | 06:14 PM
bucky katt's Avatar
just the good ol' ngk copper plugs, same ones this car has had since it had 4 miles on it. i'll cgeck the codes in the morning.
Quadcouper
02-02-2014 05:13 PM
rockcandy
05-19-2007 06:35 PM
90lxstang
04-05-2007 04:05 PM
zachary1988
10-20-2005 04:22 PM
rufusnruby
08-06-2005 11:54 PM
