clicking box in console
Old 03-15-2009 | 12:37 AM
lenasaturn's Avatar
Default clicking box in console
my daughters 93 4 door sedan wouldn't start,after boosting it the lights were dim,then you can turn off the switch,take out the key,and a clicking is coming from the box mounted in the center console at the e-brake handle.turn the switch on and it stops,but everything is dead like the battery is totally dead.Any ideas will be appreciated,thanks
Old 03-15-2009 | 10:14 AM
LenaSaturn -
That clicking sound is coming from the control module for your passive restraint seatbelts. On the Insturment Panel Fuse Block (IPFB) inside the car, locate and remove the 20amp fuse (PREST)that controls the seatbelts. Only downside will be that you have to connect and disconnect your shoulder belts by hand.
Possibly other issues at work here, but do that and recharge the battery, to make sure it remains charged properly
Old 03-15-2009 | 12:46 PM
,and if you have signs of ever having a leaking battery, replace the positive cable.
dwd375
07-27-2015 10:42 PM
dwd375
07-25-2015 07:12 AM
Yleetsj
01-03-2015 11:50 PM
blaisa
12-21-2014 09:51 AM
winkler91
07-26-2011 01:29 PM
